Do you really mean "reformatting" or do you actually mean "factory reset"? There are significant changes between 374.x and 386.x so a factory reset is very much advised.Currently my ASUS RT-AC68U (Rev A1) on johns 3.0.0.4.374.43_53D7j9527. Working great btw, but is it possible to update to the latest Merlin 386.x without reformatting? (JFFS is enabled. Don't know the necessity for it.)
If the JFFS partition size changes going to the new firmware then it will be reformatted automatically, you don't need to to it manually.I meant reformatting. A factory reset is no problem. Expected that one.
After the router boots up for the first time after installing the new firmware I would do a hard factory reset. This will wipe the JFFS partition automatically.There is so much to read, so many tips and tricks on this forum. In some cases the JFFS needs a reformat, some don't. As far as I can remember, I never enabled it. That's why I asked. But if it's not important, good.
I think you mean MB not Kb. The Merlin firmware contains two separate firmware images, one for the old models and another for the newer model. That's why it's twice the normal size.A second doubt was the difference is file size. johns fork is ca 23.3Kb and Merlin 94.3Kb.
Welcome To SNBForums
