updating ssh
Mathieu
Hello Small net builders
I have been using the MacOS terminal for my (very limited) ssh interactions with the router.
Upon opening the terminal, it now displays a message offering to update to zsh, which I am tempted to do.
Should I update it or not? Am I at risk of losing prior functionalities if I do so?
Thank you
That would only change your local shell to zsh. If you ssh into the router you will be using the router's shell. So the question is how much do you use the Mac's shell for local work.
Thank you
Apple has switched the default terminal to zsh. I am using it now but its not required and you can go back if desired.
updating ssh
Thanks Colin
I think I've got it: that would only be relevant for my interacting with the Mac from outside. Which is never.
updating ssh
Thanks bluzfanmr1
Good to know it is reversible.
Thanks Colin
... or locally on the Mac. Don't confuse your Mac's terminal session shell (zsh, sh, bash, ksh, etc.) with ssh (a network protocol) they are completely different things.
