shrike4242
Currently, I have an Asus RT-N56U that I've been extremely happy with for almost the last year. Running the current stock ASUS firmware, it's been running without any issue connecting the following on my home network:
2 home laptops, wireless 5GHz connections
1 work laptop, wireless 5GHz connection
2 Ethernet-connected printers
HTPC, 360, PS3, Wii connected via Ethernet switch to MoCa bridge
5 Tivos connected via MoCa bridges
NAS (if I can find one that works for my purposes, hopefully will be a Synology DS1512+) connected via Ethernet
The router is connected to a Charter 30Mbps / 4Mbps cable modem connection recently, though had run a 24Mbps / 3Mpbs UVerse connection without issue. Currently, the router is located on the upper floor of a 1700 sq ft single-floor house, close to the middle of the floor. So far, I've had no connection issues from the router and have had 3-5 bars of signal strength consistently. Shortly, it'll be moved into the basement of the house at one end of the floor, with most of the wireless devices being upstairs on the opposite end of the house. It's an open ceiling over the router, though most of the basement is a drop ceiling with a ceiling grid.
I wasn't sure how the N56U would work in that situation with being in the basement with no external antennas, so I thought about doing an upgrade to the RT-N66U with the things I've read about it having better range with the external antennas and 450Mbs on both 2.4Ghz and 5Ghz. Though, from what I've read, it seems a little more squirrel-y than the N56U and the firmware doesn't seem to be as solid. The heat concerns also seem to be something I'm curious about, though if it's in a basement, it should work better to keep cool.
If I've been happy with the N56U, would it make sense to look into the N66U? Has the firmware matured enough to have it be as solid as the N56U and be a worthwhile swap? The original reviews I've found were back around when it was initially released, though I know a number of firmware revisions have happened since then, though the early reviews said it was a bit flaky. More recent reviews seem to be better, even though some random product reviews on Amazon and NewEgg tell some issues with units dying quickly and other issues.
The N56U has been running so well, I'd hate to give myself issues with making a change to something less reliable.
