HedonistiX
Hello,
I recently replaced my stock AT&T U-Verse router with Netgear R6100. Main reason being I bought a new Smart TV, which could not pick up wireless signal from old router. After reading in some TV forums, I concluded this newer TV is not compatible with old router (not sure if it's N or G, it's 1 year old). The TV has since connected flawlessly after I replaced the router.
Questions:
(these may be super basic, please go easy on me)
1. How do I "delete" my old wifi ID from my old router? Even though old router is disconnected, this old wifi ID is still "available". I finally completed the move to the new wifi ID as "default" wifi of all our gadgets: desk/laptop/iPhones/iPad/PS3, ROKU3, etc. But the old wifi ID is still there as "available". It may also be good for my education how this is possible, i.e.: in my mind, when I unplugged the old router, the old wifi ID should not be showing anymore. Also, will this old wifi ID pose any security issue?
2. Our wireless U-Verse box stopped working properly since I replaced the router. It is asking me to "connect", push WPS, it will connect and show pictures, then will stop after 2-3 mins and will ask me to reset the box again. I already tried resetting and the problem persists. 2 potential problems: defective box or box is "confused" with the 2 existing wifi connections (old and new). I tend to think the box is defective because it will connect and show proper picture for 2-3 mins before it starts to freeze and ask me to reset, but then again, probably related to my question No.1, it may also be possible the box can't connect properly to the new router. And not sure if this is a related info: the main U-Verse box is working fine because it is sitting next to the router and I have Ethernet connection from box to router. I do not know how exactly the wireless box work but guessing there should be some sort of connection to the main box as well as the router.
Appreciate the help!
--H
Questions:
--H
