Upload stats incorrect
darekd
I recently upgraded my RT-AC68U to Merlin 384.5 and I noticed that whenever I download anything my upload stats show that I uploaded 9 times more data at the same time (Traffic Monitor). While downloading, i was checking Real Time and it was showing correct data. Last 24 Hours was incorrect the sames as daily and monthly. I restarted my router multiple times but that didn't help. NAT Acceleration is disabled. Any help would be appreciated.
This is what I'm taking about
Fix coming in 384.6, you can try the alphas if you can’t wait until stable release.
I am having a similar problem with my RT-AC3100. Looking for answer when I found this. My AC3100 is showing a random upload of 4GB and has a very similar screen to darekd. Frequency is every 4 to 7 days. Started on May 19, 2018. I have convinced myself that it is not real by looking at the Statistic part of the Traffic Analyzer in detail. The data there match the daily numbers minus the 4GB upload. Plus the fact that my upload max is 1000 kbps (usually runs 600 to 700 kbps) and I see no degradation in my normal service. Hopefully 384.6 will fix it.
Multiple reports of this already fixed in 384.6 alpha builds.
Thanks, I guess I will have to start monitoring the alpha build threads. Just went there and see my exact problem discussed.
