You connect the UPS to whichever device you want to receive notice that power has been lost and that can also do something with the information, i.e. initiate a clean shutdown.I have a Cyberpower 900AVR.
Right now, the USB goes from the UPS to my computer. Do I want to instead have the USB go from the UPS to the NAS?
when DS enter safe mode, then it will send a command to UPS to ask it to shutdown, so DS will shutdown with it, this is how some user may require the function, however if you do not require the function, then please do not enable it, however if DS enter save mode and UPS run on batter mode, then once UPS gain power, the DS will stuck on safe mode and will require manual reboot"
Thread starter | Title | Forum | Replies | Date |
T | Synology will try to lock you into using their branded drives | Synology | 5 | |
Synology DS918+ doesn't start with the drives in | Synology | 9 | |
B | Synology DSM Version: 7.2.2-72803 (2024-08-26) | Synology | 1 |
Welcome To SNBForums
