URL blocking per device ?
Prasad1337
I noticed the firewall has the ability to block specific URLs but for the entire network. Is there any way I can achieve this for specific devices without using something like DNS filtering or openVPN ?
Thanks and kind regards
Prasad
You can try to handcraft some iptables rules like:
# Block example.com from specified devices
iptables -A FORWARD -i br0 -m mac --mac-source xx:xx:xx:xx:xx:xx -p tcp -d example.com -j DROP # Substitute device1's MAC for the x'es
iptables -A FORWARD -i br0 -m mac --mac-source xx:xx:xx:xx:xx:xx -p tcp -d example.com -j DROP # Substitute device2's MAC for the x'es
in /jffs/scripts/firewall-start
Note that this is not foolproof: if example.com translates to multiple IPs, this rule will not be effective.
