USAccess on Merlin firmware How-to
jbadry
I put together some notes on how I setup usaccess for netflix on my new RT-AC68U. Previously I had an RT-N16 with Tomato and dnsmasq in the gui.
1. Install 'Merlin' firmware for the RT-AC68U (or other models).
http://forums.smallnetbuilder.com/forumdisplay.php?f=42
2. Enable Telnet and confirm the JFFS partition is enabled.
Administration -> System tab
3. Telnet to the router with Putty
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
4. Change to the /jffs/configs directory
cd /jffs/configs
5. Create a file dnsmasq.conf.add and paste the contents below into it.
vi dnsmasq.conf.add
with vi, hit ESC and ZZ to exit/save
http://www.lagmonster.org/docs/vi.html
(this list may be dated; for the most part I only care about netflix)
----- contents of the dnsmasq.conf.add file -----
server=/pandora.com/107.20.195.51
server=/hulu.com/107.20.195.51
server=/huluplus.com/107.20.195.51
server=/netflix.com/107.20.195.51
server=/nflximg.com/107.20.195.51
server=/nflximg.net/107.20.195.51
server=/spotify.com/107.20.195.51
server=/fox.com/107.20.195.51
server=/foxfdm.com/107.20.195.51
server=/demdex.net/107.20.195.51
server=/abc.com/107.20.195.51
server=/nbc.com/107.20.195.51
server=/fxnetworks.com/107.20.195.51
server=/rdio.com/107.20.195.51
server=/comedycentral.com/107.20.195.51
server=/cwtv.com/107.20.195.51
server=/amazon.com/107.20.195.51
server=/pbs.org/107.20.195.51
server=/pbskids.org/107.20.195.51
server=/usopen.org/107.20.195.51
server=/nfl.com/107.20.195.51
server=/bbc.co.uk/107.20.195.51
server=/itv.com/107.20.195.51
server=/channel4.com/107.20.195.51
server=/pandora.com/107.20.190.171
server=/hulu.com/107.20.190.171
server=/huluplus.com/107.20.190.171
server=/netflix.com/107.20.190.171
server=/spotify.com/107.20.190.171
server=/fox.com/107.20.190.171
server=/foxfdm.com/107.20.190.171
server=/demdex.net/107.20.190.171
server=/abc.com/107.20.190.171
server=/nbc.com/107.20.190.171
server=/fxnetworks.com/107.20.190.171
server=/rdio.com/107.20.190.171
server=/comedycentral.com/107.20.190.171
server=/cwtv.com/107.20.190.171
server=/amazon.com/107.20.190.171
server=/pbs.org/107.20.190.171
server=/pbskids.org/107.20.190.171
server=/usopen.org/107.20.190.171
server=/nfl.com/107.20.190.171
server=/bbc.co.uk/107.20.190.171
server=/itv.com/107.20.190.171
server=/channel4.com/107.20.190.171
6. Restart the router.
Is this just to pypass the region restriction, that's adding those you don't require to use vpn to get those channles if you're in Europe?
