USB Application and network issues. (RT-AC68U)
kohht
Hi, I just updated to the latest 374.43_2 Merlin build. Restore to default settings.
After setting up, I found out there a few number of issues. I'm not very sure if anyone had same problem as me.
When I click on USB application, it will show "Loading app list..." for a second and next, "Updating...".
It will stuck at "Updating..."... reboot didn't help. Also, tried restore default settings still no go.
Next, about my home network issues.
This issues also appear to be ASUS itself.
I try to explain this problem as I don't understand the fault and can't figure out why.
Every 20 to 30mins, my network will went down. All devices connected to Asus router via WIFI, LAN, VPN will fail together.
The down time was quick to resolve itself. The WIFI didn't disconnect tho, just the network "routing" cut off... Or I would say, unable to reach host.
This cause my smart TV (Lan) to stuck at "buffering" and my relative PC games to be logout for "host unreachable". (The WIFI still intact)
This also applied to my VPN. Whenever I turn on my VPN on iPhone or iPad and for 20mins, it will disconnect me away. Stating PPTP terminated in System Log.
The router didn't reboot itself. The LED lights still work. I'm not very sure what weird problem I got. Check the uptime and still running.
I'm totally confuse with this "routing cut" issues.
bring up for awareness! :(
