USB drive not working in AMTM after upgrade to 3006.102.4
neotod
Hello,
after updating my GT-AX6000 firmware from version 388.8.4 to 3006.102.4 AMTM can't find my USB drive anymore.
It looks like it is correctly mounted, but I can't see it in AMTM anymore even after formatting it with the fd utility.
I tried to change drive and update to 3006.102.5 but it didn't help.
Is there anything I can try before a factory reset?
Thank you!
Did you leave the USB drive attached when you updated the firmware? Quite a few recommend not having a USB drive attached to the router when performing a firmware update.
Have you ejected the USB drive and reconnected it?
Have you physically powered off the router and restarted it?
Have you checked the USB drive in another computer?
Have you tried formatting the drive for FAT32 or NTFS in another computer then reformatting the drive through AMTM?
yes I did, unfortunately.
anyway the first thing I tried was switching to a brand new USB drive (SSD) and it didn't solve the problem
tried everything, I don't think the issue is hardware related, the drive works fine.
