Hi all -
I'm pretty sure my amtm/Diversion USB drive has failed. It is still recognized as a drive (i.e., it shows up via fdisk -l and is recognized as an unmounted HP flash drive in the GUI) but it's failing the amtm/entware automatic disk check at boot and it is not mounting. As expected, Diversion disappeared, and Skynet has the USB error.
Heres the fdisk-l output:
and the disk check log
I'm guessing the answer is a failing drive and just need to trash it and start with a new one, but I don't want to lose everything. I think I have the Diversion white/blacklists backed up, but I'm not sure what else is stored on the USB (vice JFFS).
Is there any way to remount the drive or backup its contents?
Assuming it is a failed drive...are there any tips on improving drive life? I've had two other drives fail in the last 6 months (they failed completely - devices weren't even recognized). I've added a 6" USB extender to help with any heat issues. If it matters, I'm running pretty much all of the add on scripts.
Thanks!
Disk /dev/sda: 31.0 GB, 31048335360 bytes
64 heads, 32 sectors/track, 29610 cylinders
Units = cylinders of 2048 * 512 = 1048576 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 29610 30320624 83 Linux
Sun Oct 18 21:52:03 CEST 2020 Waited 5s for NTP to sync date
Sun Oct 18 21:52:03 CEST 2020 Probing 'ext4' on device /dev/sda1
Running disk check v2.9, with command 'e2fsck -p' on /dev/sda1
e2fsck: Read-only file system while trying to open /dev/sda1
Disk write-protected; use the -n option to do a read-only
check of the device.
Sun Oct 18 21:52:03 CEST 2020 Disk check done on /dev/sda1
Thanks!
