Release USB unmounted? AX88U
LaMpiR
Hi good people.
I have an issue with my usb drive. I know, it's not reliable and I have ordered m.2 with cooling case for it. But it will all arrive in a few days.
My usb is not there, below is the log from amtm dcl. I have reformated it, but still. Even tried restarting the router. I's high time for me to do a whole new firmware, but simply havent found time for it. Will probably do it with new ssd. I have so many mac lists for guest wifi (iot) and dhcp, but yea. Will have to do it.
In the meantime, how can I mount it back and use it? My Skynet is down and I am not a fan of that :)
RT-AX88U (aarch64) Kernel-4.1.51 FW-3004.388.8_4
Mon Feb 17 11:03:50 UTC 2025 Waited 2s for NTP to sync date
Mon Feb 17 11:03:50 UTC 2025 Probing 'ext4' on device /dev/sda1
Running disk check with command 'e2fsck -p' on /dev/sda1
skynetusb: recovering journal
skynetusb: clean, 4871/940240 files, 694707/3753980 blocks
Mon Feb 17 11:03:50 UTC 2025 Disk check done on /dev/sda1
Wed Feb 19 22:00:51 UTC 2025 Waited 1s for NTP to sync date
Wed Feb 19 22:00:51 UTC 2025 Probing 'ext4' on device /dev/sda1
e2fsck: Read-only file system while trying to open /dev/sda1
Disk write-protected; use the -n option to do a read-only
check of the device.
Wed Feb 19 22:00:51 UTC 2025 Disk check done on /dev/sda1
Wed Feb 19 22:05:59 UTC 2025 Waited 1s for NTP to sync date
Wed Feb 19 22:05:59 UTC 2025 Probing 'ext4' on device /dev/sda1
Wed Feb 19 22:05:59 UTC 2025 Disk check done on /dev/sda1
Sun Feb 23 20:53:46 UTC 2025 Waited 1s for NTP to sync date
Sun Feb 23 20:53:46 UTC 2025 Probing 'ext4' on device /dev/sda1
Sun Feb 23 20:53:46 UTC 2025 Disk check done on /dev/sda1
Mon Feb 24 10:52:10 UTC 2025 Waited 2s for NTP to sync date
Mon Feb 24 10:52:10 UTC 2025 Probing 'ext4' on device /dev/sda1
Mon Feb 24 10:52:10 UTC 2025 Disk check done on /dev/sda1
Mon Feb 24 10:57:11 UTC 2025 Waited 1s for NTP to sync date
Mon Feb 24 10:57:11 UTC 2025 Probing 'ext4' on device /dev/sda1
Mon Feb 24 10:57:11 UTC 2025 Disk check done on /dev/sda1
_____________________________________________
END FILE
