I was blaming my Synology DSM software for not initiating a spin-down in long-idle USB3 drives. I tried three US3 to SATA drive interfaces... only one did the spin down...
Seagate branded enclosure with Seagate 2TB inside. Never spins down.
USB3 drive dock (drop-in the drive). Does time out/spin-down the 2TB above and a 1TB Hitachi.
USB3 adapter (no enclosure).. does not spin down.
I don't know if the spin-down that does occur was initiated by the NAS software or by the hardware in the drive enclosure/adapter. I suspect the latter. It's not the drive or drive config.
Under windows, on my ASUS motherboard PC, the drives spin down immediately when unmounted by user choice.
(I did look on the NAS vendor's web site- they only enclosures they list are few in number and apparently Taiwan-only brand names)
I want to buy another USB3 drive enclosure and spend $30 or less. And get one with "Green" power management to support spin-down. I cannot tell from the Newegg and Amazon product descriptions which ones do so. Any clue?
