USB3 HDD problem with Firmware RT-AC68U_3.0.0.4_376.48_1 and newer
Mheel
I have a problem with firmware RT-AC68U_3.0.0.4_376.48_1 and newer.
When i try to configure samba or ftp users read and write functions, I only se ........................................
On the firmware RT-AC68U_3.0.0.4_376.47 and older it looks like this.
Does anyone else have the same problems?
Kind regards Magnus
Kind regards Magnus
I remember having such a blank line one time, but, as far as I can remember, I rebooted and it just came back to normal. I also run an AC68u and I'm now on .49
I'm sure you tried a reboot, but also try with another browser.
I have tried reboot, factory reset, etc. Nothing helps exept going back to firmware .47 I have tryed every firmware from .43 to .49 the problem is only on firmware .48 and .49.
Since Asus revamped some of the USB code on the webui, some special disk configurations are having issues. Disks that have a special partition at the start of their table (either a swap, or a hidden system partition) can have trouble being properly handled by the webui. Try simplifying your partition table.
I tried to format the disk on a win 8 computer to get a clean start but that didnt help. So i think i need more help on how to check and change the partionen table. I am using a usb3 cabinett whit two hdd tjat are running raid 1.
I have connected the usb3 hdd to my Linux server and run testdisk and it says that it is a Non partitioned media.
Is this correct or do i want to change it to something else?
Kind regards Magnus
