usb3-port1: disabled by hub (EMI?), re-enabling...
Ubimo
Hello
Today, I noticed some strange entries in my syslog:
Feb  7 03:04:11 kernel: usb usb3-port1: disabled by hub (EMI?), re-enabling...
Feb  7 03:04:11 kernel: usb 3-1: USB disconnect, device number 2
Feb  7 03:04:11 kernel: cdc_ether 3-1:1.0 eth7: unregister 'cdc_ether' usb-ehci-platform.0-1, CDC Ethernet Device
Feb  7 03:04:11 hotplug: remove net eth7.
Feb  7 03:04:12 kernel: usb 4-1: new full-speed USB device number 2 using ohci-platform
Feb  7 03:04:12 kernel: usb 4-1: not running at top speed; connect to a high speed hub
Feb  7 03:04:12 kernel: cdc_ether 4-1:1.0 eth7: register 'cdc_ether' at usb-ohci-platform.0-1, CDC Ethernet Device, 00:1e:10:1f:00:00
Feb  7 03:04:12 hotplug: add net eth7.
Feb  7 03:04:12 hotplug: set net eth7.
I have a AC86U with latest Merlin FW and a USB 3.0 stick in the 3.0 port for the swap file. (Diversion, Skynet, unbound) and a USB-LTE stick in port 2.0 for failover.
Can someone please enlighten me with these entries? Should I be concerned?
Your USB-LTE stick disconnected and then reconnected. My guess is that this is something the LTE stick does and not a problem with the router.
Hello, I didn't want to create new thread so I might get the answer her. Can someone confirm that using ASUS-MERLIN 386.4 on RT-AC68U I can share and access the USB disk outside my internal lan? Before installing Merlin software I was able to do that and it was quiet simple with original ASUS firmware, but now I stuck of trying. I enabled "Cloud Disk" "Smart Access" "AiCloud 2.0" "Network Place (Samba) Share / Cloud Disk" "FTP Share" and turned ON WAN access. But still can't reach the files from outside (for example using my mobile phone internet). What I am doing wrong? Or what settings could effect that I can't reach? There is an APP on mobile phone called "AiCloud" but no luck to add the drive using manual or quick setup. I have installed AdBlocker Diversion with pixelserv-tls, nothing else.
I manage to find it by myself. pixelserv-tls uses 443 port, and by default AiDisk uses the same port. Reinstalling Diversion I got that notification to change it to 9443, I agreed, and then manually connected using 9443 port. SO if someone will have the same issue just change the port.
