Use Both 2.4 and 5ghz at same time
italyguy01
With the Asus RT-AC66U, can you use both 2.4ghz and 5ghz on a wireless network simultaneously?
So if I have two 2.4 and two 5ghz devices on all at the same time?
Thank you. Does anyone else have random wireless drops?
Which firmware version are you using? If you're not on Asus .270, you might try that. If you are on Asus .270, you might try Merlin's 24 Beta 2, which had older wireless drivers in it.
