Used By Existing BSS
ApexRon
Every 15 minutes this get posted to the System Log:
“May 18 08:32:33 acsd: eth6: COEX: downgraded chanspec 0x1909 to 0x100b: channel 4 used by exiting BSSs”
Can anyone advise as to what this trying to tell me? Is “eth6” the WiFi?
RT-AX86U Pro running 3004.388.7
Your router is set on Auto channel and with 20/40MHz bandwidth on 2.4GHz band.
Fix a working well 2.4GHz channel at 20MHz bandwidth and all ACSD messages will disappear.
The 2.4GHz band has been set to a Control Channel of 11, not Auto. I have changed 20/40 to 20. Will monitor.
Detected interference will force the radio to switch to 20MHz channel bandwidth. Fixed to 20MHz will stay there without ACSD involvement.
