Fingers
I have a RT5300 running Merlin 380.65.4 I had set up a vpn connection with PIA using these settings:
https://helpdesk.privateinternetacc...ing-up-an-Asus-Router-running-Merlin-Firmware
Everything was running ok.
Then I entered another VPN providers config as PIA didnt have the country I needed for the devices I wanted to connect. As soon as I introduced this new VPN, the PIA one stopped woking and will not even start. I dindnt alter any settings apart from introdunce the new vpn. (that works great).
These are the logs when I try to start the PIA vpn:
Any help would be appreciated, is this a bug when using two different providers?
Apr 9 00:40:08 custom config: Found /jffs/configs/dnsmasq.conf.add, but custom configs are disabled!
Apr 9 00:45:06 rc_service: httpd 559:notify_rc start_vpnclient1
Apr 9 00:45:07 openvpn[5507]: Options error: If you use one of --cert or --key, you must use them both
Apr 9 00:45:07 openvpn[5507]: Use --help for more information.
Apr 9 00:45:08 kernel: EMF_ERROR: Interface tap11 doesn't exist
Apr 9 00:45:08 kernel: EMF_ERROR: Interface tun11 doesn't exist
Apr 9 00:45:08 custom config: Found /jffs/configs/dnsmasq.conf.add, but custom configs are disabled!
Apr 9 00:46:36 rc_service: httpd 559:notify_rc start_vpnclient1
Apr 9 00:46:38 openvpn[5810]: Options error: If you use one of --cert or --key, you must use them both
Apr 9 00:46:38 openvpn[5810]: Use --help for more information.
Apr 9 00:46:38 kernel: EMF_ERROR: Interface tap11 doesn't exist
Apr 9 00:46:38 kernel: EMF_ERROR: Interface tun11 doesn't exist
Apr 9 00:46:38 custom config: Found /jffs/configs/dnsmasq.conf.add, but custom configs are disabled!
Apr 9 00:47:44 rc_service: httpd 559:notify_rc start_vpnclient1
Apr 9 00:47:46 openvpn[6029]: Options error: If you use one of --cert or --key, you must use them both
Apr 9 00:47:46 openvpn[6029]: Use --help for more information.
Apr 9 00:47:46 kernel: EMF_ERROR: Interface tun11 doesn't exist
Apr 9 00:47:46 kernel: EMF_ERROR: Interface tap11 doesn't exist
Apr 9 00:47:46 custom config: Found /jffs/configs/dnsmasq.conf.add, but custom configs are disabled!
Apr 9 01:00:14 disk_monitor: Got SIGALRM...
Apr 9 09:39:59 rc_service: httpd 559:notify_rc start_vpnclient1
Apr 9 09:40:00 openvpn[30970]: Options error: If you use one of --cert or --key, you must use them both
Apr 9 09:40:00 openvpn[30970]: Use --help for more information.
Apr 9 09:40:01 kernel: EMF_ERROR: Interface tap11 doesn't exist
Apr 9 09:40:01 kernel: EMF_ERROR: Interface tun11 doesn't exist
Apr 9 09:40:01 custom config: Found /jffs/configs/dnsmasq.conf.add, but custom configs are disabled!
Apr 9 00:28:31 rc_service: httpd 559:notify_rc start_vpnclient1
Apr 9 00:28:33 openvpn[2459]: OpenVPN 2.4.0 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Mar 29 2017
Apr 9 00:28:33 openvpn[2459]: library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.08
Apr 9 00:28:33 openvpn[2460]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Apr 9 00:28:33 openvpn[2460]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 9 00:29:03 openvpn[2460]: RESOLVE: Cannot resolve host address: uk-london.privateinternetaccess.com:1198 (Name or service not known)
Apr 9 00:29:33 openvpn[2460]: RESOLVE: Cannot resolve host address: uk-london.privateinternetaccess.com:1198 (Name or service not known)
Apr 9 00:30:08 openvpn[2460]: RESOLVE: Cannot resolve host address: uk-london.privateinternetaccess.com:1198 (Name or service not known)
Apr 9 00:30:43 openvpn[2460]: RESOLVE: Cannot resolve host address: uk-london.privateinternetaccess.com:1198 (Name or service not known)
Apr 9 00:31:18 openvpn[2460]: RESOLVE: Cannot resolve host address: uk-london.privateinternetaccess.com:1198 (Name or service not known)
Apr 9 00:31:43 rc_service: httpd 559:notify_rc stop_vpnclient1
Apr 9 00:31:48 openvpn[2460]: RESOLVE: signal received during DNS resolution attempt
Apr 9 00:31:48 openvpn[2460]: Could not determine IPv4/IPv6 protocol
Apr 9 00:31:48 openvpn[2460]: SIGHUP[hard,close_context usr1 to hup] received, process restarting
Apr 9 00:31:48 openvpn[2460]: OpenVPN 2.4.0 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Mar 29 2017
Apr 9 00:31:48 openvpn[2460]: library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.08
Apr 9 00:31:54 kernel: EMF_ERROR: Interface tun11 doesn't exist
Apr 9 00:31:54 kernel: EMF_ERROR: Interface tap11 doesn't exist
Apr 9 00:31:54 custom config: Found /jffs/configs/dnsmasq.conf.add, but custom configs are disabled!
