poolbeetse7en
I wonder if someone can point me in the right direction here. I am trying to set up the following SSIDs on my AX56U router. I have YazFi installed, and the requirements are:
- 2.4Ghz Guest Network for IOT Devices (Disable local access/intranet access) 192.168.3.x
- 5Ghz Guest Network for Other (Disable local access/intranet access) 192.168.5.x
After some testing, it seems that these devices are still able to communicat with my main 192.168.1.x network devices which I would like to isolate. Am I missing something plainly obvious? The intranet setting is disabled for both and I have tried Guest Network #2 for both 2.4 abd 5Ghz with the same result. I may be missing something in YazFi as this is my first time using. Really appreciate the help. Thank you!
