using 376.45 firmware lighttpd issue with modules symbols
benoitm974
I've just bought and flash my AC-RT68 vith merlin asuswrt .45. I firs tlike to say this is great firmawre and good approach for me. I'm trying to run the lighttpd dameon that is part of the firmware. I've created a basic lighttpd conf file in /jffs but I'm facing 2 issues:
The first one seems to be with the library/mofule which seems to be hard coded to the /home/merlin path:
lighttpd: symbol 'smbc_list_directory': can't resolve symbol
2014-09-15 15:32:10: (plugin.c.169) dlopen() failed for: /home/merlin/asuswrt.ac68/release/src/router/lighttpd-1.4.29/_inst/lib/mod_dirlisting.so
2014-09-15 15:32:10: (server.c.771) loading plugins finally failed
But After I found that lib are in /usr/lib and that you can override the module path with -m optionI get similar error:
2014-09-15 15:33:27: (plugin.c.169) dlopen() failed for: /usr/lib/mod_dirlisting.so
2014-09-15 15:33:27: (server.c.771) loading plugins finally failed
æ
Any idea what is happenning to the lighttpd modules ?
I'll reply to myself, you need to add a minimum list of module to satisfy mod listing dependancies:
server.modules = (
"mod_access",
"mod_auth",
"mod_alias",
"mod_compress",
"mod_redirect",
"mod_webdav",
"mod_usertrack",
"mod_smbdav",
"mod_rewrite",
Then it works
That lighttpd binary was modified by Asus for AiCloud's specific needs. I don't think it's a good idea to use it for anything else, not knowing the extent of Asus's customizations to the code.
