I'm using an RT-AC68P with 378.56_2 firmware in repeater mode, and I see that there is are eth0, eth1, and eth2 interfaces. I'm assuming that eth0 is the interface for the 2.4GHz. wireless supplied by the repeater, eth1 is the interface for the 5GHz. wireless supplied by the repeater, and eth2 is the wireless interface on the repeater used for the connection between the "main" router and the repeater. In my case, I specified that the repeater should connect to the 5GHz. wireless from the "main" router.
Is this correct, is eth2 the interface between the "main" router and the repeater?
This setup seems to work really well, by the way. My mobile wireless clients are automatically switching to the stronger of the two wireless networks available to them on 5GHz., both have the same SSID. I can tell which router a client is using fairly easily, since the "main" router has IPv6 available, and the repeater does not. That's a pretty fast and easy test to run on the client that I'm currently using.
