Evil Overlord
Need advice on planned FIOS network
I just bought a new house. Happily, all the rooms have multi-media outlets - each with a phone jack and sometimes cable outlet visible, but with cabling behind for another coax cable and a CAT5e cable. There must be a dozen or so outlets and thus cables. The cables from them all terminate in a phone box in a downstairs closet. The phone box has:
I plan to get Verizon FIOS internet service. The previous tenant had it, so the installation is basically done. Verizon's web site suggests that they'll hook up the FIOS box to the house's coaxial cable network.
I own a cable modem and a wireless G router. My primary goal is internet sharing, but I also have an NAS that needs to be available across the network (shared files, and eventually work as music server for Sonos/SlimDevices/...)
I'd like to hook the FIOS up to my CAT5e network instead. It seems to me that if I use the coax, I'll need a cable modem at each physical connection, then a wireless router. Whereas if I hooked up directly to the CAT5e network, all I'd need for each physical hookup is a regular LAN cable to the computer.
Question 1 - Main query
If I hook FIOS up to the CAT5e network, what is the intermediate device? A patch panel, a switch, a router, a hub, ...? Ideally something really small that fits in the phone box. Otherwise, something I can hang on the wall beside the box. Cheap is good! (Gigabit speeds unnecessary).
Question 2
If I get FIOS hooked up to the CAT5e in the closet, can I hook a computer directly up to the outlets in the house?
Question 3
If good so far, I'm assuming I can connect one ore more wireless routers to the network just by plugging the network cable into the wall (and presumably messing with IP addresses).
Question 4
If Verizon insists on hooking FIOS up to the coaxial network instead, can I have a cable modem in the closet that THEN hooks up to a switch/... and through that to the whole house network?
PS Minor question. The phone panel already has too little room for the number of phone outlets in the house - one cable is disconnected. Is there a simple way to extend the panel or replace it with a larger one?
PPS The previous tenant used just a wireless router connected to (something I just glimpsed), for a network covering only the garage, so I can't learn much from their setup.
PPPS I haven't signed up yet. Plan is to get 20/2 internet at about $50/mo. Other option is ComCast cable (6/1), for about the same price.
- Phone: a panel with inputs from all the phone outlets jacked in, a jack for the incoming phone line (from the phone company), and one more (RJ13?) that I believe is connected to the security system.
- Cable: another, similar panel, with inputs from all the cable outlets jacked in, and an incoming cable (from the cable company)
- CAT5e: all the CAT5e cables terminate in 'raw' ends - that is, they have no plugs on the end, just bare cable. Presumably, I can use a crimper to easily put on plugs.
Question 2
Question 3
Question 4
