I am experiencing occasional hiccups / freezes during conference calls with my home network over MoCA.
I live in an apartment building that provides Gigabit Internet. It has a wireless access point in each unit (IBT U6-IW-US) with 4x GbE RJ45 ports. I am getting 925Mbps up and down over wired connections to my laptop, versus around 350Mbps over wireless. So obviously, a wired connection has my preference.
I decided to utilize the coax outlets in the apartment for a wired connection to my home office desk with 2x Motorola MM1025 MoCA 2.5 adapters, like this:
IBT Access Point - MoCA Adapter - Coax outlet - Coax cable behind walls - Coax connector - Coax cable behind walls - Coax outlet by desk - MoCA Adapter - Computer
All other coax outlets, including the 'incoming coax cable' from TV/Internet provider are disconnected. Also, I exclusively use CAT8 ethernet cables.
When I disable WiFi on my laptop and connect directly to the MoCa adapter, I am getting the 925Mbps speeds, but am occasionally experiencing hiccups. These hiccups do NOT happen when I connect directly to the access point (either wired or wirelessly).
What could be causing this? Thank you for reading...
