Virtual Server / Port Forwarding - No data in table.
AreYouShpongled
Hello.
After upgrading my AC3200 from .60 to .61 I lost all my port forwardings.
This is not such a big deal. The problem really is, when I create new ones, they
don't stick any more.
Creating one generally is ok, but when I create a second one, they both disappear.
Hello.
How much nvram is free, according to the Tools -> Sysinfo page?
you have no free memory....try to factory reset again.....this is big problem with ac3200 routers....ac3200 routers are one big fail.....i am not happy with it....
sent from Kodi 17 Krypton
Did a factory reset. Cleared up some memory:
NVRAM usage 57574 / 65536 bytes
Now I'm not getting any dhcp client information. It says 8 clients connected. The list is completely empty :S
I have rebooted several times.
The router cannot know about already existing leases, only about those it issues. Give your clients some time, once their lease expires, they will request a renewal, at which point the router will know about them.
Thank you for answering so quickly RMerlin.
Even if I force a dhcp renew on my client the router won't catch it?
Forcing a lease renewal would also work.
