VLAN and Port
bgsmith
This is definitely a newbie question. Can I configure an RT-N66R with Merlin 374.40 to have Port 4 run 2 VLANs? The default VLAN1 and a VLAN4? Port 4 terminates at an engenius ENS-200 wireless AP which I would like to broadcast 2 SSIDs, each SSID tied to a specific VLAN. One SSID is to broadcast the local home network to the barn and shop. The other SSID is a connection for a renter to use that provides access to the internet but not my home network.
Thank you
Brad
Thank you for the reply
Did you search the forum for similar setups?
One is this post.
Thank you for replying. Yes. I have looked at that post carefully and tried to search for others. The referenced post and others I have looked at separate the VLANs on different physical ports. The question I have is whether I can have 2 VLANs on the same port.
Brad
