pilotmarcog
I have two VLANS, one for the regular ISP connection and one for the VPN. I want the 86U to connect to the switch using 802.1Q VLAN Tagging and then create two separate SSID's, one for each VLAN.
¿Is that possible?
I would appreciate a pointer. You can get technical!
Thanks and regards,
¿Is that possible?
Thanks and regards,
