VLAN ID settings for TUF AX6000
dr_dunno
I just bought a TUF AX6000 router, and thought I could use it to replace my ISP provided router. My existing ISP-provided router is connected to the fibre termination panel, and the router is configured to use PPPoE. I missed the part where a VLAN ID configuration is required on the router. And I am finding that the TUF AX6000 does not have the ability to configure VLAN ID. Unfortunately, I can't return the router to the store where I purchased it from due to their sales policy, so I have to live with my purchase.
Is there any way to flash a custom firmware on the TUF AX6000 which will enable VLAN tagging? Or is there any other way for me to configure the VLAN ID on the TUF AX6000?
Thank you.
Regards,
DR
