Hello everyone
I'm running RT-AC66U with 380.62_1 and following the examples found in this forum to build SSID-to-VLAN mapping.
Setup is pretty straight forward: AP--trunk--Switch--trunk--Router
Port 4 on AP is configured as a trunk with 2 VLANs - vlan1 for default private Wi-Fi and vlan3 for Guest Wi-Fi.
The problem I see that Guest Wi-Fi simply works as it should, but for some reasons my regular private Wi-Fi clients are hitting the router on vlan3 (which is guest) and not on vlan1 (which is private). Private clients get associated with the right SSID, then DHCP works as it should on the right VLAN, then the 1st packet after the IP is assigned is sent over the wrong VLAN. Confirmed running tcpdump on the router port.
Here is the script I'm using:
Some diagnostics output:
Any suggestion or recommendation?
Thanks!
#!/bin/sh
PATH="/sbin:/usr/sbin:/bin:/usr/bin:${PATH}"
robocfg vlan 1 ports "4t 8t"
robocfg vlan 3 ports "4t 8t"
vconfig add eth0 3
ifconfig vlan3 up
brctl addbr br1
brctl addif br1 vlan3
brctl delif br0 wl0.1
brctl delif br0 wl1.1
brctl addif br1 wl0.1
brctl addif br1 wl1.1
ifconfig br1 up
nvram set lan_ifnames="vlan1 eth1 eth2"
nvram set lan_ifname="br0"
nvram set lan1_ifnames="vlan3 wl0.1 wl1.1"
nvram set lan1_ifname="br1"
killall eapd
eapd
admin@RT-AC66U-xxxx:/tmp/home/root# brctl show
bridge name bridge id STP enabled interfaces
br0 8000.xxxx no vlan1
eth1
eth2
br1 8000.xxxx no vlan3
wl0.1
admin@RT-AC66U-xxxx:/tmp/home/root# robocfg show vlan
VLANs: BCM53115 enabled mac_check mac_hash
1: vlan1: 4t 8t
3: vlan3: 4t 8t
Thanks!
