Diveblaster
Hi
I just bought a AXE16000 and installed Merlins latest firmware.
I was going to play around with VLAN options that should be found under LAN -> VLAN. I cant find that tab under LAN at all..im using GT-AXE16000_3004_388.5_0_rog_nand_squashfs.pkgtb. Is it hidden or do i need stockfw for that?
Thx for all the work u and others put in
