Vlan troubles
profnl
Hi Guys,
i got a problem. My provider has vlan 34 for internet and vlan 4 for iptv.
So i use the option under lan and that works perfect:
Now there is one cable to a 5 port swith for my tv, macmini, 5ghz wifi spot and the iptv box. iptv box works because there is only vlan 4 on port 4. So how do i get my internal lan (i think vlan 1) and vlan 4 on my LAN port 4.
I know that its only possible on the terminal:
And now the big question what are the correct commands to configurate this?
gr maarten
Hi Guys,
in which menu is this ? I didnt find such menu on my RT-87U.
Thanks.
