vnStat vnStat not starting due NTP sync
langesgnu
Hi everybody,
since some time, I have the issue that after a reboot vnStat is not starting, as it seems NTP sync is not fast enough for vnStat. Other scripts don't seem to have that issue and/or are waiting for NTP sync. What I see in the log after a reboot is:
Apr 12 09:17:18 scMerlin: Waiting for NTP to sync...
Apr 12 09:17:23 Entware: Starting Entware services on /tmp/mnt/86Udisc
Apr 12 09:17:23 vnstat: Starting monitoring for interface eth0
Apr 12 09:17:23 vnstat: NTP not synced, exiting
Apr 12 09:17:23 S61unbound: Waiting for NTP to sync before starting Unbound...
Apr 12 09:17:31 ntpbootwatchdog: Still waiting for NTP to sync [30 secs]...
Apr 12 09:17:31 rc_service: service 3915:notify_rc restart_ntpd
Apr 12 09:17:31 custom_script: Running /jffs/scripts/service-event (args: restart ntpd)
Apr 12 09:17:31 ntpd: Started ntpd
Apr 12 09:17:31 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Apr 12 09:17:31 rc_service: udhcpc_wan 3729:notify_rc stop_ntpd
Apr 12 09:17:31 rc_service: udhcpc_wan 3729:notify_rc start_ntpd
Apr 12 09:17:31 rc_service: waitting "stop_ntpd"(last_rc:restart_ntpd) via udhcpc_wan ...
Apr 12 09:17:31 custom_script: Running /jffs/scripts/service-event (args: stop ntpd)
Apr 12 09:17:31 ntpd: Stopped ntpd
Apr 12 09:17:32 custom_script: Running /jffs/scripts/service-event (args: start ntpd)
Apr 12 09:17:32 ntpd: Started ntpd
Apr 12 09:18:22 ntpd: Initial clock set
Apr 12 09:18:22 scMerlin: NTP has synced, scMerlin will now continue
Apr 12 09:18:22 rc_service: ntpd_synced 4265:notify_rc restart_stubby
Apr 12 09:18:26 rc_service: ntpd_synced 4265:notify_rc start_vpnserver1
Apr 12 09:18:30 ntpbootwatchdog: NTP has synced!
Currently I am running my AX86U Pro on 3006.102.4_beta1, but it was the same on 3004.388.8_4 and previous releases. I have the local NTP server enabled, also the scMerlion NTP Ready startup check and NTP boot watchdog script.
Anybody having an idea what could be done to avoid having to start vnStat manually every time after a reboot?
It should start from /jffs/scripts/post-mount even if the init script fails. What’s in the post-mount script? Maybe things need to be re-ordered in there to ensure vnstat runs after Entware.
Hi everybody,
The little snippet of the syslog you provided is not enough to get the full context. There should be more to the story as told in the syslog.
Can you provide the entire syslog file that captures all the events during the reboot sequence? You can redact any sensitive details (e.g. public WAN IP address, Admin Username, etc.).
As @dave14305 alluded to in his post, there should be a call to the dn-vnstat add-on script somewhere in the /jffs/scripts/post-mount script that should eventually restart the Entware service during reboot.
Thanks for the fast answer. Enclosed another syslog version from a reboot that I just did, now complete but excluding some private data and the VPN server data. If I read the log correctly, then vnstat is when Entware & Diversion are started, but where there is no NTP sync yet. Then later on there is another call for a start, which does not seem to work.
The content of the post-mount script is actually just the following:
/jffs/addons/amtm/mount-entware.mod # Added by amtm
swapon /tmp/mnt/86Udisc/myswap.swp # Added by amtm
/jffs/scripts/dn-vnstat startup "$@" & # dn-vnstat
Thank you for providing the syslog file showing the full reboot sequence.
I have submitted a pull request to the "vnstat-on-merlin" repo on GitHub. This PR contains fixes to make sure that the vnstat Entware service is started during the reboot sequence after NTP is synced.
If you would like to test this modified script (new version 2.0.7), you can download it using the following commands:
Bash:
curl -LSs --retry 3 --retry-delay 5 --retry-connrefused \
  https://raw.githubusercontent.com/de-vnull/vnstat-on-merlin/dd6721f93e1b8a93c02b24a4e9c43c3ddb87e119/dn-vnstat.sh \
  -o /jffs/scripts/dn-vnstat && chmod 755 /jffs/scripts/dn-vnstat
Once the new 2.0.7 script version is downloaded, you can reboot the router at your own convenience to check if vnstat has been started (as expected) after NTP is synced.
HTH
