Good Morning,
Using Merlin 378.55 on a Asu RT-N66U.
I have two port that is forwarded to my network, when I don't use VPN client it is working perfectly, at the moment I enable a VPN client (TCP). Port forwarding stop working ?
Do I have to setup something else in the router to get port forwarding working over VPN client. I check the NAT passthrough setting everything is enable except PPPOE relay, my current Nat loopback is set to Merlin in firewall !
Tanks for any hint !
Sylvain
Sylvain
