lobloblob3
Router RT-88AXU
I have used Merlin v384.19 OpenVPN server and have an OpenVPN client connection from my Synology NAS box (DSM v7). After upgrading Merlin to v386.3_2, the OpenVPN client connection from the Synology NAS box no longer can connect. After about a minute it says 'Connection failed. Please check your network settings.'. The ovpn file looks like this:
client
dev tun
proto tcp-client
remote XXX.XXX.XXX.XXX 1194
float
cipher AES-256-CBC
auth SHA256
keepalive 15 60
auth-user-pass
remote-cert-tls server
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
<tls-auth>
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-auth>
resolv-retry infinite
nobind
Any idea what could be the problem? OpenVPN connection from Windows work fine.
Thanks!
client
dev tun
proto tcp-client
float
cipher AES-256-CBC
auth SHA256
keepalive 15 60
auth-user-pass
<ca>
</ca>
<cert>
</cert>
<key>
</key>
<tls-auth>
</tls-auth>
nobind
Thanks!
