Vpn client
clvk07
hi
try to connect to a vpn service (ivacy) using latest firmware .42 and asus n66u. However I get this error:
20:15:30 pptp[1542]: Using interface ppp5
May 12 20:15:30 pptp[1542]: Connect: ppp5 <--> pptp (38.84.134.91)
May 12 20:15:34 pptp[1542]: CHAP authentication succeeded
May 12 20:15:34 pptp[1542]: LCP terminated by peer (MPPE required but peer negotiation failed)
May 12 20:15:34 rc_service: httpd 319:notify_rc restart_vpncall
May 12 20:15:37 pptp[1542]: Connection terminated.
May 12 20:15:37 pptp[1542]: Modem hangup
May 12 20:15:44 pptp[1542]: Hangup (SIGHUP)
May 12 20:15:44 pptp[1542]: Terminating on signal 15
May 12 20:15:44 pptp[1542]: Exit.
it works fine with wiundows and android. Any ideas?
The latest firmware is 374.42
Read the changelog (in zipfile), it may be solved.
hi
MPPE is disabled by default. See this post on how to enable it.
Ignore my post above, this is the wrong thread.
Hi RMerlin,
Please, is this step still need it in 380.65?
Thank you.
The webui has a "PPTP Option" setting where you can select encryption.
