VPN killswitch reset?
Joh_Kla
I'm running 386.10 and now 386.11 on an RT-AC86U.
The VPN killswitch (enabled through the VPN Director) was activated (properly + because of VPN server downtime, probably) but now no matter if I connect/reconnect to the VPN server and/or reboot the router it seems that the VPN killswitch remains activated.
That is, all of the traffic which normally/previously went through the VPN still can't, even when the router successfully connects as normal to the VPN server.
So, my question is: is there a way, either through the GUI or through the command line, to "reset" the VPN killswitch to deactivate it after it has been activated?
Thanks in advance for any help!
