Hi guys,
Hopefully someone can help me with this as I'm no expert with such things.
I have noticed that when I set up my VPN on my PC using either OpenVPN or WireGuard that it allows free access to ports for the programs on my computer without needing to forward them. I can use uTorrent as an good example as I can freely swap the port usage around. When I have a port set in uTorrent and I use a port checking program to check that port on the IP that my VPN has assigned me the port shows as open. When I close uTorrent the port then shows as closed. I can change the IP in uTorrent and it still works accordingly.
Now if I set up my VPN on my router using OpenVPN and try the same thing the ports are closed. I tried forwarding the ports but that doesn't work as I guess it shouldn't as it's using a tunnel to connect to the VPN provider. My VPN provider doesn't offer any way to forward ports from their admin page.
Am I being silly with something here or does OpenVPN work differently on a router? I would assume that when the client is set up as a PC directly that maybe it uses a DMZ like state over the tunnel but when on the router it doesn't. I've tried setting up DMZ on the router to the PC and that doesn't work but it seems obvious that wouldn't. I assume there is maybe a setting I am missing. I have tried to search for it but I can't find much info on VPNs on routers other than setting them up and they don't show anything that I haven't done in my own setup.
Thank you.
Thank you.
