Asus 68u run asuswrt-merlin last update and I run OpenVPN on it. The wireless router is set in bridge and my isp they tell me that NAT is disabled.
The routers are placed in my summer cottage and I live far away (300 km) and am stucked when the vpn not function which has happen now and last week also. Last week got help from a friend living there. He powered off the 240v to the cottage and on again (in the outdoor box) which woke up the wireless routers internet.
I have from my alarm company a electric socket which I can power off and on with sms but sorry to say, just now only before the asus router. I have of course used this sms and powered the asus off and on, but I still haven't got internet.
I discover through googling that there is some difference between asus and asuswrt-merlin on the DDNS page. This is the use of DDNS "Internal" og "External" (new in Oct. 2018). I found that the original asus don't have this choice. Looking deeper I found that External is ment for Dual DAT, but as mentioned above it should not be my case. Therefore I use Internal.
There is two other thing I want to ask about:
1. On the first screen after login there is a lightbulb with yellow color - where the asuscomm.com is coming up. Is this wrong color?
2. On the wireless router - last time I changed it, I had to reset it to get it work. I forgot to disable wifi before I put it in brigde. Off course that wifi don't work thereafter, but can this be a trigger and give me the missing internet-problem?
I suppose I'm still out of business if the wireless router must be reset (with a thin needel), but hope it isn't the case.
Is the config - asus 68u with OpenVPN after a wireless router a known and OK configuration?
Enclose two pics and hope for advice.
