VPN only for selected devices, possible?
crusher888
Hello everybody
would it be possible to connected the router to a vpn server and then have only selected devices use that vpn server instead of all the devices connected to the router?
thanks in advance.. I tried to google around but i found no references.
OpenVPN Client Settings => Advanced Settings => Redirect Internet traffic => Policy Rules => Rules for routing client traffic through the tunnel
Thanks but could you tell me what should I use for source ip and destination ip? If for example
I want just my pc to go through the tunnel , and my pc local ip is 10.0.0.50 then what should I put in source ip and destination ip ?
Then you only need to use 10.0.0.50 in Source IP and leave Destination IP blank (will fill automaticly with 0.0.0.0) Choose VPN and (+) and hit Apply.
Block routed clients if tunnel goes down yes/no your choise.
