VPN server, double nat
Cake
I am double NAT'd.
I use the openvpn client on the router. It works great.
I want a VPN server to also run. It works great (openvpn) -> if the openvpn client is off.:mad:
That's the problem!
What do I need to do to get the router's openvpn server to listen to the ISP provided IP (wan ip, or in my case a host at noip), and not the IP from the openvpn client.
I just need 1 device on my lan with a static ip to be not on my internet vpn (headless raspi running a openvpn server), or to change a setting/config via ssh on the router to make both work at the same time.:)
please suggest what I need to do.
