Hello everyone,
I have set up the VPN Server and so far everything works fine.
How ever, I noticed that multiple clients can connect with one OpenVPN User credential at the same time.
This means I create one user "Thomas" and if he shares his login+client file, then several other users can login at the same time.
Is there a way to allow only one active connection per user?
Also:
Will setting "Client will use VPN to access: Internet only" disable any access inside the local network (e.g. file shares, SMB,...)?
Thanks!
Also:
Thanks!
