My current network is running off of a Netgear AC1450 upgraded to a 6300 v2 with DD-WRT. I recently purchased an ASUS RT-AC68P from BB and am planning to use this as my main router placed in the basement in the middle of my house. From there I plan to run ethernet cable to a switch behind my TV. Connected to the switch I will have my Roku, and my old Netgear router acting as an Access Point, which I will hardwire to my TV through one of the LAN ports on the router.
I would like to run a VPN (TorGuard most likely) through the Netgear Access Point to use with the MLB.tv app. Is it possible to do this so that only the WiFi signal from the AP and the TV are being run through the VPN? I didn't want to slow down the rest of the network in the house, and aren't overly concerned with my other traffic needing the VPN.
Thanks in advance.
John
Thanks in advance.
John
