VPN TLS errors hack attempts
Gravityz
i recently switched from synology vpn(forward port 1194 to synology) to the native Asus vpn server.
as far as i can see everything is working.
this morning i discovered some errors in the log.
it looks like somebody tried to use the VPN from outside but i was asleep.
is this a sign of somebody trying to get in
Jun 7 04:31:21 vpnserver1[31021]: TLS Error: cannot locate HMAC in incoming packet from [AF_INET]199.195.248.205:55958 (via [AF_INET]xxx.xxx.xxx.xxx%eth0)
Jun 7 05:23:15 vpnserver1[31021]: TLS Error: cannot locate HMAC in incoming packet from [AF_INET]146.88.240.4:54036 (via [AF_INET]xxx.xxx.xxx.xxx%eth0)
Jun 7 07:16:41 vpnserver1[31021]: TLS Error: cannot locate HMAC in incoming packet from [AF_INET]142.93.148.22:38917 (via [AF_INET]xxx.xxx.xxx.xxx%eth0)
Jun 7 08:08:16 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 1000 mbps full duplex
these are the settings i used
looks like extra HMAC security is really needed
anything else i can change to up the security?
Those are normal error messages generated in response to internet port scanners. Totally expected if you run your VPN server on the default port (UDP 1194). Change it to a different (random between 5001 to 32767) port and the messages will go away.
