VPNDirector Source/Destination Port-Based Split-Tunneling Rules Not Possible?
garycnew
All:
I'm in the process of migrating from Asuswrt-Merlin 384 => 388 and noticed VPN Director as an option for VPN Source/Destination Address-Based Split-Tunneling.
In Asuswrt-Melrin 384, I configured my Source/Destination Port-Based VPN Split-Tunneling Rules in the nat-start script as follows:
   iptables -t mangle -I PREROUTING -i br0 -p udp -m multiport --sport 11111,22222,33333,44444,55555 -j MARK --set-mark 0x2000/0x2000
   iptables -t mangle -I PREROUTING -i br0 -p tcp -m multiport --sport 11111,22222,33333,44444,55555 -j MARK --set-mark 0x2000/0x2000
   iptables -t mangle -I PREROUTING -i br0 -p udp -m multiport --sport 10000:10999 -j MARK --set-mark 0x2000/0x2000
   iptables -t mangle -I PREROUTING -i br0 -p tcp -m multiport --sport 10000:10999 -j MARK --set-mark 0x2000/0x2000
I just want to confirm that VPN Director is only Source/Destination Address aware (NOT Source/Destination Port aware) and that I should continue using the nat-start script for my Source/Destination Port-Based Split-Tunneling Rules?
Thanks, again.
Gary
No, Merlin uses ip rule which does not have sport/dport option compiled in (intentional?).
Usage of fwmarks have not been possible in fw due to ai-protect uses all bits already. But it's used in various addons, like x3mrouting, Wireguard manager et.c.
Sorry, I need to retract this statement. Looks like this have changed in 388 fw:
admin@RT-AX86U_Pro:/tmp/home/root# ip rule add from 192.168.28.2 dport 1888 lookup 123
0:      from all lookup local
89:     from 192.168.28.2 dport 1888 lookup 123
90:     from all to 192.168.100.128/25 lookup main
90:     from all to 192.168.100.2 lookup main
10010:  from all to 192.168.0.0/16 lookup main
11210:  from 192.168.100.0/24 lookup wgc1
11211:  from 192.168.128.1 lookup wgc1
11212:  from 192.168.128.100 lookup wgc1
11213:  from 192.168.128.120 lookup wgc1
11214:  from 192.168.128.110 lookup wgc1
32766:  from all lookup main
32767:  from all lookup default
Can't believe I didn't find this before, looks like you have a better option, but this is not exposed in vpndirector but I would recommend update your script to use this instead.
The reason it's not used by VPNDirector is some of the platforms will have an instant kernel crash whenever trying to configure a port with iproute2.
Bummer! As always, using undocumented features comes with a risk. Atleast with my RT-AX86U-Pro the rule got added without any crash. I really hope Asus works this out as it would be so much easier.
Guess that using the (fragile) fwmark (or possibly TOS marks) is the only option.
@RMerlin and @ZebMcKayhan
Thank you for confirming and providing the reason why Port-Based Split-Tunneling is excluded from VPNDirector.
I'll manually test each line of my 384 nat-start script and confirm that they successfully migrate to the 388 firmware.
Respectfully,
Gary
