VSERVER DNAT bypassing ipset filters
WQ6N
If this has been already vetted, please point me in the correct direction. New to the AC5300 and ASUSWRT-Merlin
I am using the gui Port Forwarding to allow external access to internal DMZ servers. I have also set up iptables INPUT ipset filters to control ingress packets. However, it is apparent that the VSERVER DNAT chains are going direct without filtering on the iptables INPUT ipset filters.
In order for me to make use of the iptables INPUT ipset filters for all ingress packets, do I need to remove the gui VSERVER rules and create FORWARD rules behind the INPUT ipset filters?
Thank you for the assistance.
The INPUT chain is for traffic that terminates at the router. The FORWARD chain is for traffic that terminates on a LAN client.
Thank you for your quick response. I understand the FORWARD chain relationship ingress to the LAN.
As an example # iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP all -- anywhere anywhere match-set BlockTheWorld src
Chain FORWARD (policy DROP)
There is no VSERVER chain
The FORWARD chain does not contain any relationship to VSERVER
# iptables -t nat -L -nv --line
Chain PREROUTING (policy ACCEPT 61386 packets, 5169K bytes)
num pkts bytes target prot opt in out source destination
1 5639 293K VSERVER all -- * * 0.0.0.0/0 xxx.xxx.xxx.xxx (WAN IP)
2 SpeedGuide rule
more stuff ....
Chain VSERVER (2 references)
1 0 0 DNAT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:8181 to:xxx.xxx.xxx.xxx(inner LAN interface):80
2 77 4588 DNAT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:xxxxxxxxx
3 188 10632 DNAT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:xxxxxxxxxx
So back to my original question, do I need to remove the existing gui Virual Server Port Forwards and handset the FORWARD rules or is there a way to move the VSERVER DNAT in behind the ipset DROP filters of the FORWARD chain?
V/R
