Helllo,
I have a RT-AC86U with installed the lastest firmware asuswrt-merlin 386.4.
Until now using the aicloud application from my phone I waked up my pc without any issue. Starting probably from one week ago in the application list device of aicloud , my pc disappeared. On the other side the second pc in the network is shown.
Usually using anydesk outside my network to wake up my pc it also has been worked (if a second pc in the same lan was online), now it works only from inside the lan.
In the utility menu of Aicloud there is manual WOL with memorized the mac address of my pc. It does not work if I am not inside my network. If I am out of the network it only works if I make a VPN to the router.
Very strange and honestly speaking I didn't remember to modify any settings on my pc or on my router.
Do you have any idea what to check and how to solve it?
