I wanted to be able to wake my computer over Internet via my smartphone so I started searching found lots of sites with instructions but none worked over Internet at least for me.
A site recommended using Asuswrt-Merlin firmware which has Wake On LAN option so I installed Asuswrt-Merlin 3.0.0.4.264.22 firmware (the latest as of this post) configured Wake On LAN and port forwarding but still can't get the computer to wake over Internet using smartphone, I even applied the following fix/workaround WOL Script Wake Up Your Webserver On Internet Traffic (replaced IP, MAC address and port with mine) but no luck.
The computer wakes from local network when packet is send from another local computer and using smartphone when connected to home WIFI so configuration seems to be OK but I want to be able to wake it over Internet through smartphone using one of the available apps, is this possible if so all suggestions are welcome.
I am using Asus RT-N66U router flashed with Merlin firmware.
Windows XP SP3 with all updates as of this post.
Dell laptop with Broadcom 440x Integrated Controller driver version 4.6
I have enabled and using Asus DDNS.
I tried following Android apps with no luck.
https://play.google.com/store/apps/details?id=net.mafro.android.wakeonlan
https://play.google.com/store/apps/details?id=com.benfinnigan.wol
https://play.google.com/store/apps/details?id=com.depicus.wakeonlan.free
