TLDR: How to make WAN GUI access as quick LAN GUI access without regard to introducing security vulnerabilities because in this case, they don't matter.
Before anybody starts with the "don't enable WAN access," just let me first state the router will not be internet accessible. So security is not an issue.
My setup - I live in a country where the internet is heavily censored and VPNs are routinely targeted and servers blocked. A constant cat and mouse game between the Country, and VPN providers. My network is set up so that I have an ISP modem then the primary router with WiFi and plugged into that router are two separate VPN routers - each using a different provider. This allows users, guests, and WiFi devices to easily jump between the appropriate service (or whichever one is working). Basically three WiFi networks a) ISP (censored) b) VPN1 c) VPN2.
VPN2 Router is running Asus Merlin and uses an applet to configure VPN access, switch servers etc. It works just fine except for one issue. The primary computer that I use for configuring the routers (mainly switching servers to working ones and updating the firmware as part of the cat/mouse game) is hard wired to the ISP Router. I have WAN access enabled on VPN1 and can easily do what I need to do on that router. I have WAN access enable on VPN2 running Merlin but it is dog slow and worse, I can not access the VPN company's applet as it fails to load for some reason [located - 192.168.1.98:8080/user/vpnApp.asp]. I could live with it if it was just really slow for the convenience of WAN access but without access to the VPN App, I have to pull out a laptop and connect to Merlin using the router's WiFi to make changes.
I've scoured this forum and the internet and I can't find anything that would seem to address my issues. My assumption giving what I have been reading is that if I could allow HTTP for WAN access like you could in the past, it might speed things up but I don't know if that will address the app issues. Are there any hidden settings I could access via SSH where I could open up WAN access or some other suggestions to make the app work other than sticking a USB WiFi dongle on my PC and using that to connect to the VPN2 network. I'm tired of pulling out the laptop. Thanks in Advance for any suggestions.
