My main router (AC68U) has WAN access enable option under Admin/System however, this option does not appear to be available to my router(s) set up as AP (AC66U & N66U). Is it possible to access AP routers if so, how??
You lost me at "On your primary router set the port for both local and remote access to port 8080". I cannot find the option(s) to set either local or remote ports
BTW: Asus RT-AC68U with Firmware:3.0.0.4.374.39 (Merlin build)
In order to access this from the Internet, you need to get access to your Home-LAN first, like with using VPN.
Welcome To SNBForums
