I'm using a GT-AX11000 with Merlin version 3004.388.7.
After updating my modem's firmware, my router suddenly stopped getting an IPv6 address. Initially, I thought the modem was to blame, but I have now found out that the built in IPv6 firewall of my asus router is blocking the DHCP request.
In the log, I see that odhcp6c doesn't get a response to the very first request and gets stuck at "Starting SOLICIT transaction (timeout 4294967295s, max rc 0)." As soon as I disable the IPv6 firewall and trigger a WAN reconnect, the router receives an IPv6 address via DHCP-PD (dynamic /64 network).
When I enable the firewall again, odhcp6c stops receiving an IP address, so the firewall obviously blocks the dhcp-request. Strangely, as mentioned this started with the last firmeware update of my Modem, before that IPv6 worked fine for a long time; I suspect that the responses to the dhcpv6-request no longer come from a Link-Local address or something other changed about the dhcp traffic. However, I don't want to leave the firewall disabled. I tried opening port 546 using ip6tables, but that didn't work. Maybe it's not enough, or I'm doing something wrong.
I would appreciate any tips!
