When the DST change occurred this morning the router disconnected and then reconnected the WAN, is that normal/intended behavior? This is with Merlin 386.5 on a RT-AC66U B1, with FlexQoS running.
Mar 13 03:00:28 watchdog: restart_firewall due DST time changed(0->1)
Mar 13 03:00:28 rc_service: watchdog 574:notify_rc restart_firewall
Mar 13 03:00:28 rc_service: watchdog 574:notify_rc restart_wan
Mar 13 03:00:28 rc_service: waitting "restart_firewall" via watchdog ...
Mar 13 03:00:29 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 13 03:00:29 custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Mar 13 03:00:29 miniupnpd[1688]: shutting down MiniUPnPd
Mar 13 03:00:29 pppd[994]: Connection terminated.
Mar 13 03:00:30 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=27722) called in unattended mode with 1 args: -start
Mar 13 03:00:30 WAN_Connection: Fail to connect with some issues.
Mar 13 03:00:30 DualWAN: skip single wan wan_led_control - WANRED off
Mar 13 03:00:31 FlexQoS: Applying iptables static rules
Mar 13 03:00:31 FlexQoS: Applying iptables custom rules
Mar 13 03:00:31 FlexQoS: Flushing conntrack table
Mar 13 03:00:32 pppd[28133]: pppd 2.4.7 started by xxxx, uid 0
Mar 13 03:00:32 pppd[28133]: Connected to xx:xx:xx:xx:xx:xx via interface eth0
Mar 13 03:00:32 pppd[28133]: Connect: ppp0 <--> eth0
Mar 13 03:00:32 pppd[28133]: CHAP authentication succeeded
Mar 13 03:00:32 pppd[28133]: peer from calling number xx:xx:xx:xx:xx:xx authorized
Mar 13 03:00:32 pppd[28133]: local IP address x.x.x.x
Mar 13 03:00:32 pppd[28133]: remote IP address x.x.x.x
Mar 13 03:00:32 pppd[28133]: primary DNS address x.x.x.x
Mar 13 03:00:32 pppd[28133]: secondary DNS address x.x.x.x
Mar 13 03:00:33 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 13 03:00:33 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=28433) called in unattended mode with 1 args: -start
Mar 13 03:00:34 wan: finish adding multi routes
Mar 13 03:00:34 FlexQoS: [*] Killing Delayed Process (pid=27722)
Mar 13 03:00:34 FlexQoS: [*] 27722 Rotarene 1616 S sh /jffs/addons/flexqos/flexqos.sh -start
Mar 13 03:00:34 custom_script: Running /jffs/scripts/service-event-end (args: restart wan)
Mar 13 03:00:35 FlexQoS: Applying iptables static rules
Mar 13 03:00:35 FlexQoS: Applying iptables custom rules
Mar 13 03:00:35 FlexQoS: Flushing conntrack table
Mar 13 03:00:36 WAN_Connection: WAN was restored.
Mar 13 03:00:37 FlexQoS: No TC modifications necessary
Mar 13 03:00:39 miniupnpd[29286]: HTTP listening on port 33904
Mar 13 03:00:39 miniupnpd[29286]: Listening for NAT-PMP/PCP traffic on port 5351
Mar 13 03:00:43 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 13 03:00:43 zcip_client: configured x.x.x.x
Mar 13 03:00:44 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=29356) called in unattended mode with 1 args: -start
Mar 13 03:00:45 FlexQoS: Applying iptables static rules
Mar 13 03:00:45 FlexQoS: Applying iptables custom rules
Mar 13 03:00:45 FlexQoS: Flushing conntrack table
Mar 13 03:00:46 FlexQoS: TC Modification Delayed Start
Mar 13 03:01:07 kernel: SHN Release Version: 2.0.2 7812743e
Mar 13 03:01:07 kernel: UDB Core Version: 0.2.20
Mar 13 03:01:07 kernel: sizeof forward pkt param = 192
Mar 13 03:01:07 BWDPI: fun bitmap = 4ff
Mar 13 03:01:07 A.QoS: qos_count=0, qos_check=0
Mar 13 03:01:11 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Mar 13 03:01:11 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=30277) called in unattended mode with 1 args: -start
Mar 13 03:01:11 FlexQoS: [*] Killing Delayed Process (pid=29356)
Mar 13 03:01:11 FlexQoS: [*] 29356 Rotarene 1612 S sh /jffs/addons/flexqos/flexqos.sh -start
Mar 13 03:01:12 FlexQoS: Applying iptables static rules
Mar 13 03:01:13 FlexQoS: Applying iptables custom rules
Mar 13 03:01:13 FlexQoS: Flushing conntrack table
Mar 13 03:01:17 FlexQoS: Applying AppDB rules and TC rates
Mar 13 03:06:00 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=32220) called in unattended mode with 1 args: -check
Mar 13 03:06:00 FlexQoS: iptables rules already present
Mar 13 03:06:02 FlexQoS: No TC modifications necessary
